Making multiple objects invisible
reserv888reserv888 Posts: 1,150
When I make a scene I often want to make multiple different renders and combine them in photoshop. I find it quite tedious to click on the eye in the scene tab to make objects I don't want to use, invisible, or make invisible under the parameters tab. Is there a faster and smarter way of accomplishing this?
It would be great if I could make the opposite, and make everything invisible with a click and then choose the few objects I want to use in that particular render.
Anyone who has a solution or an idea?
  • cecilia.robinsoncecilia.robinson Posts: 2,208
    You could go to Shader Tab, highlight multiple objects (by holding Control while clicking) and set opacity to 0%.
  • Richard HaseltineRichard Haseltine Posts: 102,792
    Better to select all of the items you want to hide, then use the Visible button in the Parameters pane. Making items transparent doesn't stop the renderer including them in calculations, and may leave visible effects depending on surface settings.
  • reserv888reserv888 Posts: 1,150
    edited October 2014
    Thanks for your fast replies. I will check it out at once. Thanks again!
    EDIT: Worked perfectly!
    Post edited by reserv888 on
