Dripster prop
A remake of an old Poser prop of mine
A long drop shaped model rigged in DAZ Studio suitable for use as a fluid prop, tadpole creature or whatever random drip shaped thing your characters might need, with posing controls
780 Polys
Features:
- Proper flat UV map with minimal seams
- A few shape morphs that can be mixed and matched or dialed negative for an assortment of shapes
- Posing Controls (NB: if you use these and then find that the figure "jumps" when attempting to manually adjust a bone, simply Undo and "Bake to Transforms" [SHIFT+B] before manipulating any bones)
- A small assortment of Iray materials, some of which use refraction/reflection and some simple shiny plastic type stuff (NB: Please note some of the materials make use of TRANSPARENCY and may not show up in the viewport with some display settings; when rendered with the Iray engine they should appear OK)
https://sharecg.com/v/97202/browse/21/DAZ-Studio/Dripster
1000 x 1000 - 292K
300 x 350 - 127K
