wire
laverdet_943f1f7da1
hello! I try to get a "false" wire effect: I mean, not the real vertex, wich are somewhere very dense, and on other areas, very sparse... NO, I'm looking for a square -patch style of wire... the scene is much too complicated to do uv map, so I'm going crazy, going nowhere with that effect!!
thank you for any help!!!!!!
This should do the trick:
Wireframe Pro
http://www.digitalcarversguild.com/plugin.php?ProductId=16
Or you could use the brush preset in 3D paint and paint on a wire using a brush of the preset brushes or of your own design.
Another option would be to use the pattern function "Wires" in the alpha channel of the shader
Alpha = "Subtract"
Source 1 = "value" of 100
Source 2 = "wires"
Adjust wire count, height and width as necessary to get the desired effect.
