Scripts drop down menu missing
Hi!
I'd like to use the Daz to C4D bridge but in my Daz Studio interface is not showing any scripts drop down menu (where the bridge should appear in).
I tried everything, like uninstalling everything and reinstalling it with the Daz install manager and without, searching all possibilities to find the scripts menu, but nothing :(
I see that many people are having the same problem but nobody came up with a working solution. So...HELP WOULD BE APPRECIATED!!! <3
Cheers
Check it hasn't been added to the File menu first. If not, how did you install? Trt creating the Scripts menu (you can do this, for example, by right-clicking on a preset, model, or script that you use often and selecting Create Custom Action), then uninstall and reinstall the bridge with DS closed, launch DS (which should execute the run Once script that adds the command to the menu), and see if the command is now present.
can you explain further pls. i was able to use the dazt o blender script directly before the 4.20.0.2 update. after that, I cant get the script coming out. for daz to blender or Daz to maya .
i ve tried installing through daz central, even manually through the github info. no use. i can get the script menu to appear.
