Frustrated
Is it just me or are the tutorials totally different than the version of software just downloaded ? When viewing the tutorials, the panes are set up completely different depending on the tutorial.. In one tutorial the free face transfer is available through the "window" tab , yet it's not there in mine.  Anyway, is there something I'm missing that says which version of software the tutorial is for?  This is rather confusing for a newbie.
I appreciate the help.
  • GordigGordig Posts: 10,174
    edited March 2021
    Different users will have their layouts set up differently; that's not really something that can be helped.
    edit: to be more constructive, you can move panes around yourself. One way is to right-click at the bottom of each pane section to open the "add pane" menu and selecting the pane you want, as seen below.
    You can also just grab the tab on a pane and drag it into another section.
    2736 x 1824 - 380K
    Post edited by Gordig on
  • SparkieLSparkieL Posts: 5
    Thank you!
  • FSMCDesignsFSMCDesigns Posts: 12,776
    Also before you start moving stuff around, make sure you save a copy of the layout (window - workspace - save layout as) that works for you so you can reload it when things go wonky which they will.
  • Thank you Michael! I seem to be needing to make a lot of screenshots lately too! Thank you for the tip on how to save the layout! I know I will need it.
  • By the weay, how doess one go about editing the title of the post? I just put "frustrated" without the details.....  I see that's an oopsie....
    Lisa
