C4D Bridge and instances/Bridge file size limit?
I'm trying to send the ROG Red Crow Inn set over to C4D via the Bridge. It's very large, and when I go to send to the Bridge it says it has "instances" that need to be coverted. Sending the whole set took so long that I'm not sure if it froze, so I sent a subset of the objects--a set of tables that have instances. The objects did come over for the most part, but parts are missing, like many of the table tops. Is there a way to better prepare the file for export using the Bridge?
Post edited by Auroratrek on
I found a partial fix in the "Instances to Object" script for Daz. It's easy to use, and seems to work pretty well to replace the instances with geometry. The Bridge is still not able to send over the whole Red Crow set, but I have been able to send over some pieces, so I guess there's a limit on the size of the file it can handle(?) In the meantime I guess I'll see if I can get it over piecemeal. I was able to export the whole set as an FBX, but the textures get a little neutered compared to how they come through via the Bridge.
