Is it possible to have one adjustment effect multiple things at once?
SchaakaSchaaka Posts: 147
In the picture I use as an example. Lets say i want to add a +10 to the X translate axis for every child in this string (is that the correct term in daz?), can I do that? Assume there isnt a morph or parameter that does what i am looking for.
If i select them all and adj +10 only the first one will get the modifier and id have to go to each one individually and add 10. As you know that gets tedious.
Thanks for any answers!
317 x 247 - 19K
  • GordigGordig Posts: 10,053
    What you're looking for is an ERC freeze.
  • lilweeplilweep Posts: 2,487
    if youre not talking about ERC Freeze - which allows you to set master/slave relationships - you might be looking for a more simple ad hoc solution
    See multiselection at around 5min mark
