Problems with PP2014 SR4 and DSON?
![sapat](https://delorean.daz3d.com/forums/uploads/userpics/654/nF071D0558C3C.jpg)
I am using PP2014 SR4 64 bit, and DSON 1.1.3.50 64 bit both in Windows 8.1.
A few weeks ago before I UD Poser to SR4, I was using SR3 and this same version of DSON and things worked fine. Now, when I load G2F into Poser, none of her FBM's will load (Gia, Olympia6, Girl6, etc.) Also, after loading, none of the FBM's built into the clothing figures are loading either.
Is there a problem with PP2014 SR4 and this version of DSON?
I normally always use G2F in DS4.6P, but as a beta tester, I have to test some things in Poser with DSON to make sure they work, so it's important I find out what is going on.
Thanks for any help you guys can offer.
You might want to try updating PoserPro to SR5 and see if that helps. Seems they fixed alot of bugs. Not sure about the latest DSON Importer, though, as I haven't gotten round to re-installing all of my Daz/Poser stuff yet.
Ok, am downloading it now and will see if it improves anything. Thanks for the advice.
