Rotate camera around object function?
Is there a function that locks onto an object so that the camera can rotate around it using the Transform Rotate Properties, basically the same functionality to "Aim (RMB)"?
One approach I was thinking was to just create a empty object parented inside the object and have the camera parented inside the empty object and use the DzNode::getXRotControl() (for example) to rotate the object. I feel like there is a better approach than this, if there is, will you be kind enough to share?
Thanks guys!
If you want to do this via script, you can use or modify this:
https://www.daz3d.com/forums/discussion/85971/a-script-to-orbit-camera-around-a-point
Thanks Praxis, I'll take a look at it!
