Resetting parameters of imported OBJ prop...
kaz42kaz42 Posts: 63
This is probably (hopefully) an easy one, but I'm probably Googling the wrong thing. :)
I have imported an .OBJ file into Daz Studio, and it came in TINY. I'm sure I could fix that by reimporting it with different settings, but I scaled the item up to 10000% in Studio and the size is correct. I saved it, set the metadata and categories, but when I load the item from Content Library it still shows as 10000% scale. Is there a way to tell Studio that I want this current scale to be 100%?
  • Richard HaseltineRichard Haseltine Posts: 102,792
    The simplest way is going to be reimport with better settings. The other option is to export what you have and then reimport that using the same preset as for the export, which is an extra step. You can save a Materials preset and apply it to the new imported OBJ if you are wanting to avoid losing that work.
  • kaz42kaz42 Posts: 63
    Thanks for the quick answer, Richard. I was hoping for something in Studio, like right-clicking on Scale in Edit Mode and having a Set option to set current to default or something. :) That workaround did perfectly, though. Thank you! Luckily, my first test object was just a set of shelves with a single mat group and no UVs, so not much work to lose. :)
    Sorry, I thought you wanted to reset it so that it was at 100% in the scene. Yes, you can change the default value - either via the Parameter settings dialogue (click the gear icon on the right of the slider) or by the Memorize commands in Edit>Object>Memorise
