can't find what I bought
I bought $105 worth of clothes and textures (and that's after the discounts) there are no readme files, or jpgs and nothing to send me to the internet to tell me where I can find my stuff. So now I'm looking for each piece one by one. Is this right? Is this supposed to be a hide and seek game. Ex: I bought Avalon Adventure Outfit and Textures. The textures aren't under material. I know it's all there, but I don't think that it should be a mystery where it is located.
How did you install these items, using DIM (DAZ Install Manager)?
If so, load DIM, in the Installed tab find the item, right click on them, and select the 'Show Installed Files' option, that will tell you where each file has been installed to, and the library that it was installed to as well. These are clickable links.
The easiest way to find them may well be in Products under 'A', but you can go to the Content Library pane, DAZ Studio Formats . My DAZ 3D Library > People > Genesis, and you should find them there as well. There is also a search function at the top of the Content Library pane, and you could use that too.
Yeah, I did the dim install. I can find all of my stuff via, search. But like The Gazer (Beholder) I found him via the search, but then it says it's located Runtime/Libraries/Characters/Daz Characters. My question is How do I find that using the content library tab? I went through poser formats then my Daz 3D Library then People Genesis and still there is no Gazer. This shouldn't be this hard to find using the content library.
I think when you hoover the mouse over the icon that the address should tell you how to find it using the content library, not where it is on the hard drive
okay I just found it, Whatever happened to the part of the install where they take you to the internet and explain how to find the content in Daz 3D that you bought? I even did the manual download and the only thing in my zip file was Content. No exe or Jpg or Readme file. Thx for your help. Now to find the rest of my stuff so I can categorize them.
If you right-click on any item in the search pane, just after you have done a search (just below Categories) a menu will appear. Select Show In > Mapped Folder, and that will take you straight to the place in the Content Library where the item is installed to.
It sounds like a lot of the stuff you're looking for is Poser content. All the files for these are inside the Runtime folder, which is inside the Content folder in the installer. Don't just stop when you see "Content", keep drilling down to see what's inside that.
JimmyC_2009 that was exactly what I wanted to know. That's brilliant. Thanks a ton
