Script Sample 'Get Store Product Data' won't work?
Hi,
I tried the script sample 'Get Store Product Data' (http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/metadata/get_store_product_data/start) but won't get any reasonable result. The only responseData I received is '"{\"error\":\"OK (7991690983107231706)\"}".
If I try the url within firefox (e.g. https://www.daz3d.com/dazApi/slab/22740) I'll get the full response with a lot of data.
How can I keep the script running?
  • Richard HaseltineRichard Haseltine Posts: 102,301
    I would suspect some kind of redirect is not working since the store update.
  • MikeDMikeD Posts: 301
    Add the lines:
    // Set the Quary String for the request
    oHttp.setQueryString( "" );
    under the
    // Set the content type for the request
    oHttp.setContentType( "application/json" );
    and it should be fine ;-)
    This works because the default string is being incorrectly initialised. Putting in an empty string clears that portion of the generated URL. Watch the change log for a full fix to the issue.
    yes
  • kabexefkabexef Posts: 77
    Thanks, I'll try it next time.
