Updated - mcjPlateOneHole - versatile morphing DS/Poser mechanical prop
the mcjPlateOneHole
right there -----> https://sites.google.com/site/mcasualsdazscripts4/mcjplateonehole
round, or square, or oval plate with a round or square or oval hole
Note that once the prop was morphed to satisfaction,
i did use mcjBoxUV http://www.daz3d.com/forums/discussion/36930/
to re-lay the UV map and obtain such an un-stretched result
i applied the free bump map .... mcjNeoprene1k http://www.daz3d.com/forums/discussion/46444/
and tiled it 40x20
( actually i had to use bizarre bump map values to invert the bumps : min=0.02 max=0 )
fig 3 is the (DS3 ) subD
800 x 450 - 221K
800 x 450 - 207K
455 x 455 - 92K
1920 x 1080 - 848K
1920 x 1080 - 855K
Post edited by mCasual on
Fig 1 - the 4 main Corners / AwayX and Corners/AwayZ morph-groups
Fig 2 - adding the Corners, Radius morph-groups
Fig 3 - adding the Corners / Sharp morph-groups
Fig 4 oops actually there were 5 slider-tweak if you add the PipeSharp and PlateSharp morph-groupings
Fig 5 The "Levels" morph groupings, only 2 levels so ...
And finally the "Sides" morph-groupings
4 sides : left, back, right, front
2 morphs : AwayX, AwayZ
Top and Bot
Plate and Pipe(Hole)
so, 32 channels
still have to do:
- reassign a materials a tad better
- re-UV?
- rename materials
- rename morphs that use "pipe" with "hole"
- create google site
- package
- publish
...under an hour left :)
Figure 2 ... yep it can also be a thick or thin, sharp or blunt-edged pipe !
Figure 3 ... and even a squary pipe with round or sharp corners
Figure 5 - the "Expanders" morph-groupings actually marshal up to 24 morphs at once
( 8 corners , the Radius, AwayX and AwayZ morphs )
the result is what you'd expect a "radius" morph to do
so that's the basic mcjPlaneOneHole
32 sides, 8-steps-edges give it a smooth appearance even when seen up close
1152 facets ( ( 4 x 8 + 4 ) x 32 )
since i use automated tools to build morphs and morph-groupings
i should be able to include a few other versions !
say
32x4, 32x2, 16x8, 16x4, 16x2,
so if your scene uses 100 mcjPlaneOnePipe as simple small washers
you'll be able to keep the polycount at 19200 instead of 115200
the groupings
Corners
pipeAwayX
pipeAwayZ
pipeBotAwayX
pipeBotAwayZ
pipeBotRadius
pipeBotSharp
pipeBotUp
pipeRadius
pipeSharp
pipeTopAwayX
pipeTopAwayZ
pipeTopRadius
pipeTopSharp
pipeTopUp
pipeUp
plateAwayX
plateAwayZ
plateBotAwayX
plateBotAwayZ
plateBotRadius
plateBotSharp
plateBotUp
plateRadius
plateSharp
plateTopAwayX
plateTopAwayZ
plateTopRadius
plateTopSharp
plateTopUp
plateUp
Expanders
pipe
pipeBot
pipeTop
plate
plateBot
plateTop
Levels
LevelsBotAwayX
LevelsBotAwayZ
LevelsBotRadius
LevelsBotSharp
LevelsBotUp
LevelsTopAwayX
LevelsTopAwayZ
LevelsTopRadius
LevelsTopSharp
LevelsTopUp
Sides
pipeBotFrontAwayZ
pipeBotLeftAwayX
pipeBotRearAwayZ
pipeBotRightAwayX
pipeFrontAwayZ
pipeLeftAwayX
pipeRearAwayZ
pipeRightAwayX
pipeTopFrontAwayZ
pipeTopLeftAwayX
pipeTopRearAwayZ
pipeTopRightAwayX
plateBotFrontAwayZ
plateBotLeftAwayX
plateBotRearAwayZ
plateBotRightAwayX
plateFrontAwayZ
plateLeftAwayX
plateRearAwayZ
plateRightAwayX
plateTopFrontAwayZ
plateTopLeftAwayX
plateTopRearAwayZ
plateTopRightAwayX
hmm i guess all that's left to do is make sure the materials are ok
and change the mentions of "pipe" for "hole"
see? earrings
the superb hair comes from http://swam3d.com/audry-hair/
tis ready
( though now i remember i vaguely promised i'd post alternate polygon-count versions .... later )
Warning - Warning - Warning - Warning -
impending update
the "Sharp" morphs are apparently not functioning correctly
though it has interesting side effects
( the tub shape is the upcoming mcjGear prop a toothless gear in this case )
update - update - update - update - update - update - update - update - update
The "Sharp" morphs have been corrected
( the maths for sharpening an external edge and sharpening a hole edge are different and i somehow inverted them )
