Daz is refusing to Spot Render
DDCreateDDCreate Posts: 1,404
edited April 2021 in New Users
I'm checking some lighting on the face of a character in my scene and Daz it's ticking away like it's spot rendering but nothing happens. I've done multiple spot renders in this environment/with this character and it worked. But now, 15mins have gone by, nothing has appeared and if I try to cancel the spot render, it locks up and I have to restart. Does anyone know what might be some causes of this? I've restarted Daz 3 times and done a full system reboot, moved the camera, saved again. Just to try to kind of jar it loose but no dice. The clock ticks and it just keeps saying "Rendering in Iray/Compiling Iray Shader 0/4 and then doesn't. I even tried just rendering the scene and nothing kicks loose.
Any info or tips would be appreciated. Thanks!
Post edited by DDCreate on
  • AgitatedRiotAgitatedRiot Posts: 4,437
    Have you tried setting render settings to default, if that works, you can bump up the render settings after you set your scene up
