offering a 100GC for a convert rigging script in carrara
hi,  i'm so sick of opening the ds to convert clothing and hair pieces and creatures.
scraping up my quid on behalf of the community,
i can offer a hundred dollar gc for a (python?) script to either
fix the general rigging skinning to work in Carrara,
the product page says carrara supports general weight, think they forgot to turn it on.
or convert rigging to triax or blended weight
or convert to carrara native rigging and weightmapping.
Thanks.
«1
  • Hi Misty,
    My 2 cents:
    Rigging can be indeed done in two ways:
    • implementing dual quaternion weightmapping in Carrara.It could be done  (rhe maths are described here). The problem is that it should result in a Carrara animation group and not a figure.
    • Converting DQS to LBS as a figure. That also could be done.
    I think the main issue in both cases is not so much weighmapping but autofit. This part I haven't figured out yet...
  • I forgot.
    In Triax weightmapping, you have a weight map per axis (bend, twist..). In Dual quaternion, by construction, you have a single weightmap for the 3 axis. That's why in G7-G8, they have split some bones in bend and twist, to add an additional map when necessary.
    When you convert from triax to dual quaternion, you have to average the 3 weight map (the method you use to average makes the difference in quality). The other way round is easier, you just have to duplicate.
    thank you.  gave me a lil gleam of hope.
    before the rigging convesion, the daz studio json script.
    the general rig has 1 array of verts and weight numbers.
    after, the script is run
    there are 5 arrays of verts and numbers.  identical numbers
    i experimented with rounding off the 4 point decimal places to see if it speeds up anything.
    didnt seem to make a difference.
    the parameter for the skinning type changes.  dual quat, general
    the blended weight has an additional array.
    the arrays are boken down under each bone.
    its 5 arrays times the number of bones.
    autofit is a nice feature.
    when i save the clothing item to carrara,
    it embeds all the morphs.  a 20mb shirt for genesis becomes over 200mbs
    the morph stripper is invaluable.
    Morph Stripper?  I vaguely recall this... where can I find it?  (Sorry, not doing much, waiting on cataract op).  crying Silene
    can sommiserate the vision problems.
    i'm playing with the hdr light domes,
    i can see only big contrasts, not seeing the subtleties
    cant see light fonts on light background
  • You can find it on ShareCG : https://sharecg.com/v/92883/browse/9/Plug-in/Genesis-Morphs-Eraser
    Merci!!!heart  And I made a donation.  Silene
  • StezzaStezza Posts: 8,054
    I forgot.
    I have no idea what you are talking about but it sounds promising cool
    can a Carrara script be made just to call the conversion utility used in DS to do the job?
  • Mimicking  the conversion to General Weight is simple enough. But, without autofit, the cloth will only fit G8 base. If you change to, for instance, to Vicky 8, you'll have some poke-through.
    I'll have to look a bit more into the matter
  • VyusurVyusur Posts: 2,235
    Dual Quaternion would be very nice in Carrara. I'm not so interested in Genesis 8 because now I mostly use my own figures. I wonder how the auto-fit feature will work with standalone figures?
    A Carrara script, no.
    A Daz script, yes, but there is only a very slight gain and you still need Studio.
    I've no idea. Actually, I don't use autofit that often. I don't like it because it distorts the UV maps and is not very natural in places like breast or  buttocks.
    Usually, I fit clothes using VWD which doesn't have those drawbacks. If I were to write a plugin on the subject of autofit, it would be using the result of the VWD static simulation to create a morph for the cloth.
    And yes, dual quaternion would be nice, even if it would be only for rigging created in Carrara.
  • Philemo_CarraraPhilemo_Carrara Posts: 1,175
    edited April 2021
    Double posting
    Post edited by Philemo_Carrara on
    i think it goes by if you have the clone.  and you need smoothing iterations
    often bikini strings dont sit right in carrara.  i go back into ds, save the autofit as morph asset and then dial it in carrara. or slider it smiley
    I meant, how it will work with dual quaternion.
    For now the autofit feature works with my figures like a charm. No need for any additional efforts.
  • AlbertoAlberto Posts: 1,436
    Thank you! smiley
    edited April 2021
    i psyched.  and hopeful.
    i've started culling my content, should solve some of the overhead of converting.
    theres a few steps i do to prep clothing for carrara.  some of it is easier to do thru editing the text in the file.
    in dsf file I delete the rigid groups.  the geograft group if there is one.
    in ds, i unparent figires from figures.  for example, hair tails from the hair cap.
    convert rigging on each piece, save character preset.  put it back together in carrara.
    to prep shader for alpha masks, i select the surfaces, use the dzdefault preset.  manually load the opacity maps.  create support morphs if needed, by saving autofits as morph assets.
    its gotten better.  in g3 the eyebrows had no supporty morphs.  eyelashes need support morphs for some heads.
    and then g8f had that rediculous toe bug.  turned out to be because not all of her verts were in the 'actor' region group.
    tried a few times to inject the missing verts with a cbr.  i think there is a lot more potential for cbr files, like visibility settings.
    ig a pz2 can do it, dont see why a cbr cant.  mebbe even swap uvs.
    morph groups, geografts, rigid groups can't be modified by a character preset.
    can't see how to skip over parts of the geometry secction .dsf.  i fix it by writing over the default dsf.
    and the way they mix up the name id and the internal idfrown.  tongue doesn't work in carrara without the extra preset work.  the scene nodes go tongue01 thru 04, but the nodes in the joint groups are gontuebase, 01 thru 03
    the g3/g9 tongue in carrara goes straight up into infinity.  remembers those infinity verts in old poser, lol
    Post edited by Mistara on
    i want to render catoon on a throne, but is killing me to have to open ds first.
    my faeries are naked and cold.
    when i save a duf or cr2 to carrara, its converting to carrara rigging?
    or is like, the figure running in a shell.dll of the original format?
    for simplifying studyng, brought in the basic wear shorts.
    this script wouldnt just be for clothes and hairs.  need it for some vehicles and dinosaurs too.
    is there a possible workflow to use the vwd on dforce clothes?
    i dont understand why we see the 'bones' moving?  They rotate, its like the skeleton isn't attached.
    do i really hazta open ds? crying  its worse than a tooth ache
  • DartanbeckDartanbeck Posts: 21,564
    Daz 3d did get dual quaternion working in their latest development of Carrara, but never released it because it still didn't work with G8 dual quaternion - according to the post made by Daz years ago.
    If When they do start development on Carrara again (smiley), I'd also like to see them implement that wonderful auto collision they use in Studio that auto-corrects for poke through.
    I guess we already have that, which I use - VWD Cloth and Hair.
    i'm happy with triax cuz it works.
    its the having to open ds to prep it is tedious
    edited May 2021
    detaching the skeleton and re attaching it loses all the morphs.
    mebbe the bones arent parented to the mesh?  cuz we see the bones moving.
    trying to read the .car file to compare an attached skeleton
    edited May 2021
    trying to compare the general basic wear shorts to blended weight basic wear shorts,
    highlighting actor, motion and constrait are greyed out.
    after detaching the skeleon, motion on general says still, other says keyframed.
    dunno if that means anything for the skinning.
    it also unlocked the littl save icon.
    349 x 498 - 52K
    whadda kicker
    the poser import has a convert skinning
    299 x 248 - 24K
  • Silver DolphinSilver Dolphin Posts: 1,608
    I like Carrara too, but have you tried the Blender bridge? I know DS is a pain and too slow to boot, but the bridge works ok and the rendering tools in Blender are great considering how expensive GPU's are right now.
