Make Her Mad and Make Her Smile Expressions for G2F Not Appearing in Poser 10 Library
yeideyeide Posts: 21
I installed these packages using DIM, and when they did not show up in the Expressions Library, I manually downloaded them and cross-checked that the files are in the right places. They are there, right beside i13's Pride Power and Passion expressions, which do show up in the library. I'm on a Mac, if that makes any difference. Any ideas?
Thanks!
    Pick one of the expressions -- what are the file types for all the files with that file name?
  • yeideyeide Posts: 21
    DUFs and PNGs in My DAZ 3D Library/People/Genesis 2 Female/ Expressions, same as the i13 expressions. The products say they include a DSON core installer, but I'm not certain what that does, except that it's supposed to make things work in Poser.
    No, the DSON Core isntaller is for DAZ Studio - the DSON Importer for Poser allows Poser to read the DSON files, usually by the use of Poser Companion Files (which thiss et doesn't seem to include). However, you can almost certainly use Dimension3D's loader script (along with the DSON Importer) to import the files via a standard browser http://d3d.sesseler.de/index.php?software=poserpython&product=dson_loader
    Well, that turned into an exercise in futility. Expressions would load and disappear in about a second. Money spent, lesson learned. Thanks for the help.
    The expression appeared and then vanished? Or the progress bar flashed by? In any event, if you purchased within the last 30 days you can ask for a refund.
    The expression appeared, and then the figure zeroed again. Thanks for the tip on the refund.
