How can you tell how tall a character is?
I know this may seem like a simple question. But I haven't run across any measuring tools.
So, if I want to know how tall character is. Or how wide a desk is.  Or the diameter of a globe?
Is it possible? And if so, How?
Thanks in advance
  • barbultbarbult Posts: 24,243
    edited April 2021
    One option is the Measure Metrics product.
    Post edited by barbult on
  • PhatmartinoPhatmartino Posts: 287
    edited April 2021
    There may be more elegant ways to do this, but the first thing that popped into my head was the fact that when you use Create > New Primitive, the Dialog that opens lets you choose the Size in Inches, Feet, Yards, Centimeters and Meters...
    If you make a Plane Primitive (Z Positive might be the most useful Primary Axis) at 100 Inches, once it's in the Scene you could alter the X or Y Scale of the Primitive in the Parameter Tab and the % should pretty much reflect how many inches if whole numbers are used for the Scale, for instance 72% would be 72 Inches/6 Feet, etc.
    Post edited by Phatmartino on
  • IceCrMnIceCrMn Posts: 2,129
    Make primitive cylinders of various legths to use as metering rods.
    For a globe, make spheres of different diameters.Experiment until you make one that fits perfectly inside the globe you want to measure.
  • SevrinSevrin Posts: 6,306
    edited April 2021
    Post edited by Sevrin on
    For measuring using primitives make the primitive one meter and adjust scale til it fit the object being measured then do the math.
  • murgatroyd314murgatroyd314 Posts: 1,517
    This is my go-to: https://sharecg.com/v/40765/browse/11/Poser/Poser-height-measuring-rulers
    Yes, it says "Poser", but it is indeed scaled right for Daz.
  • OstadanOstadan Posts: 1,125
    It also helps when using such rulers to use a non-perspective view like Front View.
