Measure Metrics issue (SOLVED)
Ikyoto
Can run script to open window that allows changes, but today the only thing I can check-mark is the height. All settings unlocked, sio why can't I make my figures a different size it the measurements I used to?
Post edited by Ikyoto on
If you click the button in the Figure Metrics dialogue just under the tabs does it show Current - Your Figure? If not it hasn't loaded or applied the settings for the figure, or you are using a figure that isn't supported. You can make your own support file if it's a currently unsupported file by going to the Configuration tab and for each measurement telling it which control to use by picking a node and then a property on the node, though that is of course a pain.
All of the "measurement" settings for the tape measures are loading as locked. manually unlocking everything has no effect. did indeed have to set nodes. learned a lot. thanks
