Subd'd Cr2 export
davidcaputokeenedavidcaputokeene Posts: 131
Is it possible and is there reference lit/tutorials etc. on how to export a 2x subd'd cr2 to poser and then import the cr2 - with the subdivided .obj reference in it into ay Blacksmith 3D? I have got as far as seeing the subdivided mesh in poser and saving as a Cr2 but when trying to import I am always directed back to find the "original' Cr2 which produces the base unsubd'd mesh. I suspect if one exports to Zbrush it's possible to obtain the CR2 back in poser in a highly subdivided state? Has anyone had any experience with trying this? Any insight or help appreciated
    What are you wanting to do - create a new figure with a higher polygon count, which won't support morphs made for the base figure?
  • davidcaputokeenedavidcaputokeene Posts: 131
    Yes exactly as long as the FBM's I make in Blacksmith will merge back to the CR2. Should work.
    Export the OBJ with no pose and the mesh divided, turn off SubD, export a CR2, open in a text editor and edit the two geometry references to point to the OBJ exported in the first step should work -though you will have lots of unuasble morph deltas in there too.
    Is there a tutorial or guide on setting subdidvide x 2 and getting the .obj from this in DS and enabling export of the CR2? I keep coming up with the low poly mesh.
    You need to edit the two references to the OBJ to refer to the high resolution mesh - but then your morphs will break. Just search for .obj to find the two lines.
