resolution
So,i did a big 5400x3600px render at 300dpi resolution for a big print.
Once it was printed, i felt like something was off. So i checked the properties via Windows File Explorer and discovered it was 72d[i.
does Carrara's resolution thing really work?
Sorry edited. Real world versus imaginary. Imaginary always wins. Good luck!
It really doesn't matter how much dpi to set up for your render.
You can easily resize your image in any photo editor. Just be sure that you check of the resample option.
I made a couple of screenshots in Affinity Photo.
thanks guys, but what i meant is that i did a 2-day long render at 300dpi, but it somehow ended up onlybeing 72dpi. no clue why.
so instead of another 2- day render, i just did Vyusur's suggestion...and accidentally saved over the original closing the program. OOPS!
can't tell if it's still good quality.....
If length and height of the picture in pixels remains the same then the quality of your picture remains the same.
i never understood why people render huge and then shrink it. can soseone explain?
Because they don't know how to do it in a simple way.
Well, Affinity Photo is a newly developed piece of wonder. It takes really good software like that to pull off enlarging without noticing a loss in quality.
Pixels are pixels, however. DPI = dots per inch, would should also equal Pixels per inch, but I could be mistaken.
To answer your question, people start large and resize down because reducing the size of a pixel doesn't lose quality (creating square edge pixelation) the way enlarging does. It can also have the side effect of making the details appear more crisp because it's essentially doing the opposite of the pixelization effect,
To test this, render something at 100 x 100 pixels (just leave it at 72 DPI) and resize it to 1000 x 1000 and examine the difference. Next render the same thing at 1000 x 1000 and see what it should look like.
I really don't think that DPI is equal to pixels per inch, but I'm certainly no expert in any of that.
https://www.sony.com/electronics/support/articles/00027623
if you use a noisy render engine, rendering huge, blurring then shrinking can be faster than rendering at the size you wanted.
DAZ iray comes to mind.
T
h
lol What happened rthere, Headwax? ;D
this is just weird. i decided to re-render a 7200x10800 at 300dpi, with faster settings, and it's still 72dpi. confuzzling
a simple test scene at 1200xwhatever at 300dpi stays at 300dpi
WEIRD
