M5 and Dynamic Supersuit Set 1 Worlds Finest not working well - is it D/S 4.5?
JENR8JENR8 Posts: 100
I am able to load M5 no issues. I load the Dynamic suit with no problems and see them. I see the World's finest cape, cowls etc. When I load the wardrobe it breaks apart or the cowl does not fit properly and appears on his neck.
I go to try and select the wardrobe separately and it will not allow it to do so - I can select all and delete only the character only. I really want to make a Batman character. Suggestions, or directions appreciated to get these to load properly..
    Are you saying the clothing doesn't show up in the Scene pane?
    How are you selecting - in the viewport or in the Scene pane? Dynamics tend to be set to be unselectable in the viewport so that they don't get in the way of posing the figure, since they are not usually intended to be posed directly.
  • JENR8JENR8 Posts: 100
    edited November 2014
    I usually do a keyword search and they appear. The clothing appears but as noted they look broken when applied.
    Post edited by JENR8 on
    I'm not sure what you mean - is the problem loading items, rather than selecting them once they are loaded?
  • SimonWMSimonWM Posts: 924
    The set includes M5 & M5 Hero versions of the cape. Make sure you are loading the correct version for your character because the scale has to be correct so the cowl fits properly. Also did you "Fit to" the character so the clothes follow your pose before draping?
