Multiple monitors & Carrara 8.5
Kodiak3dKodiak3d Posts: 223
I just upgraded to 8.5 ($32.50 after all the discounts!) and I've hit a bit of a problem. I was running 3 monitors with 8.1 with no problem, but I can't seem to get 8.5 to run even 2 monitors unless I switch off Full Screen Mode and just manually drag the window to the size I need. Unfortunately, this comes with problems of its own. Anyone else having a similar problem or (better yet) have any solutions to suggest?
  • Kodiak3dKodiak3d Posts: 223
    Update: I have it running 2 monitors now, which may be acceptable. It works with two when I choose the center and right monitor, but not the center and left. It could be because the center and right monitors are on the same video card, but that's just a guess.
  • rampart_1576840087rampart_1576840087 Posts: 504
    edited January 2015
    Could not delete posting
    :red:
    Post edited by rampart_1576840087 on
  • mikael-aronssonmikael-aronsson Posts: 584
    I only have to monitors so not sure, but I have to say I have not had any problems at all with this, when you say center and left, is the left monitor the number "1" monitor ? I think Carrara is picky that the left monitor is 1 and the one to the right of it is number 2.
