How much can I customize the folder structure?
As my asset library is growing I'm finding it very tedious to look for outfits, props, etc because the folders are all named after the artist/brand name. Can I make my own folder of "Cyberpunk Stuff" and put what I want in there (including sub-folders)?
  • LyonessLyoness Posts: 1,616
    If you do, you will break the smart content and metadata.  so if you rely on those, you should not customize your folder structure.
  • NorthOf45NorthOf45 Posts: 5,541
    You can make Custom Categories to classify your assets any way you want. These are links to the physical locations that you can group and structure in a way that you find convenient. In your Content Library, under Categories, make a new tree for your customization. You can start with the same structure as the DAZ Studio formats (i.e., Animals, Architecture, Environments, People, Props, etc.), or not, as you see fit, and grow it as you go. You can add entire branches of products and then move them around as you like. In the Content Library, right-click on any folder and select "Create Category from..." to place it where you want. These categories will also show in the Smart Content panes so that you can focus your selections better.
    There is also Turbo Content and Content Wizard that promise to do the same or similar sort of thing, but I cannot speak as to their abilities.
