Xiao Mei Promo Hair
mpearce
I'm looking at the attached promo image for Xiao Mei, and I can't figure out the hair. I had looked all over, and decided it was OOT's Maria Hair for V4. Indeed, the top, and particularly the front hairline looks spot on. However, I tried it, and it doesn't look the same. The hair showing in the promo image is shorter, and has a little twist at the ends that make the tips come to sort of a point. Does anyone have a better idea of what hair this promo image was made with?
1000 x 1300 - 234K
Here is a quick render of Xiao Mei with OOT Maria Hair, so you can see the difference.
Okay, I'm looking over the product description again, and I see a bunch of morphs listed, including for making the hair shorter and giving it more volume. However, these aren't showing up as parameters for the hair. So evidently, my problem is figuring out how to access and use morphs from what is an old Poser format hair figure.
You probably used Autofit to apply the hair to Xiao Mei (because the hair is for V4, and Xiao Mei is a Genesis 2-based figure). According to DAZ's notes about using Gen 4 content with Genesis, autofit does not transfer the morphs. That might explain why the morphs you want have disappeared.
One workaround suggested in the notes is to simply parent the hair to the figure's head, rather than auto-fitting.
Morphs do get transferred now they are just hidden so you must have Show Hidden checked.
Edit: See thread linked below, poster has good tip for using Auto-Fit with hair.
http://www.daz3d.com/forums/discussion/49204/
Thank you. And the notes for the hair talk about differences when only parenting. But here comes the dumb question: How do I do that? I know generally how to parent an item to another, but how do I load them item without it being fit to the character? And then how do I fit it? Maybe there's a tutorial about this, but I haven't found it.
Yes! It took me a minute to find that option, but there are all the morphs! Thanks, folks!
Thanks everyone for the good advice! I had to parent the hair and manually fit it, rather than use autofit, to eliminate the creases described in the linked thread. The hidden morphs took care of the styling :)
