Administrator issue at installation with Carrara 8
edited November 2014 in Carrara Discussion
I understand that this issue has been discussed at length and that there is a fix by logging in through Terminal in Mac OS X, but after half an hour of searching I can't find it. (so I don't need an answer if someone can just point me to the discussion that explains the fix)
Anyway... I'm running OS X 10.8.5. After a successful installation, I'm prompted to enter my serial number which I do. I'm immediately presented with an error message telling me that I have to be logged in as the administrator (which I thought I was). My serial number field goes blank and I'm forced to run it as a trial, but only once. Once I'd quit and re-launched Carrara I'm told that the trial version has to be run at least once by the administrator. (and that my trial is now expired so I can't even run it as a trial for a few weeks)
Please help.
(and if 8.5 is the only solution, is there an upgrade option? I only see a once-off purchase price which seems a bit unfair to force us to throw away the previous version just to upgrade by a ".5" )
Post edited by stephen_86af37fb6e on
  • Richard HaseltineRichard Haseltine Posts: 102,118
    Moved to Carrara Discussion.
  • edited December 1969
    Thank you for moving my post into the correct forum.
    ... um, do you have a solution to my problem?
    I think you need to login as a root user and enter the serial number that way.
    This is an issue that Windows users had quite a bit when Vista was released, but you don't see it very often anymore. Since I don't use Windows, I'm not sure if the fix was from MS having a retarded extra level of security by default, or if it was a DAZ introduced bug because they didn't adhere to MS's protocols.
    Hopefully something can be done about it when C9 comes out.
  • DartanbeckDartanbeck Posts: 21,709
    He's on MacOS10.8.5
    He's on MacOS10.8.5
    I know that. I was pointing it out for the likes of you! ;-P
