Appcrash
I am still running DAZ 3, since DAZ 4 will not locate my folders correctly.
I am struggling with a problem where DAZ crashes, when I exit it.
Any idea how to fix this ?
OS: Windows 7 (64 bit)
Problem signature:
Problem Event Name: APPCRASH
Application Name: DAZStudio.exe
Application Version: 3.1.2.32
Application Timestamp: 4d645d8a
Fault Module Name: QtCore4.dll
Fault Module Version: 4.5.2.0
Fault Module Timestamp: 4ad8ae71
Exception Code: c0000005
Exception Offset: 0000000000164702
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1033
Additional Information 1: d8a6
Additional Information 2: d8a60abba7114a12e7c18869734e0968
Additional Information 3: 65bf
Additional Information 4: 65bf0ab0962982dd5b4e7d6656a177d8
There isn't really enough information there - your system details might help.
What is the problem you are having with content directories in DS4?
I have been using DAZ, since version 2. And across 4 computers. I had backups of my content folders in case of hard drive failure.
On this computer, my Drive C is too small for DAZ, so it is installed on Drive E. DAZ 3 has no problem with showing me folders, but DAZ 4 will not load my folders, located at E:\daz 3n4\3.1.2\My Library and E:\daz 3n4\3.1.2\Old Library
DAZ 4 will also not load my saved files from DAZ 3.
You've tried right-clicking on DAZ Studio Formats in the Content Library pane, selecting Add Base Directory, and selecting one of those folder, then repeating for the other? All of my content directories are on drives other than C:
DAZ 4 was reinstalled. It detected my folders, but I cannot figure it how to access them.
To load content from disc (rather than through categories or Smart Content) you use the whatever Formats groups in the Content Library pane - Window>Panes(Tabs)>Content Library.
