Daylight and point light renders ?
LimeyLimey Posts: 19
I have a large moonlight scene that works very well with applicable daylight lighting adjustments. The scene also has a very small region that needs a point light as well. Of course when the daylight option is used other lights no longer work.
Question.....Is there a way to activate other lights and still use the daylight option. I feel sure there is but my attempts to find the options have miserably failed.
I could use a distant light for my moonlight effects but I already have other renders that use the daylight option so I don't really want to return to those and make lighting amendments.
 Thanks
  • Richard HaseltineRichard Haseltine Posts: 102,374
    Use Dome and Scene, but don't assign a map to the Environment HDR and it will act like Sun and Sky.
  • LimeyLimey Posts: 19
    Thanks so much for the fast reply.....Your suggestion works a treat. The results are excatly what I was looking for.
    Phew.....I thought there must be a solution. I will be using this technique quite a bit.
    Thanks again Richard.
