render problem with Kool's Annabelle
![Erik Heyninck](https://delorean.daz3d.com/forums/uploads/userpics/945/nB87B40039B1F.jpg)
in New Users
Hi all,,
I have this render error in IRay (see image, forehead). I do not see this in the viewport.
I use Annabelle and Annabelle hair by Kool.
Anyone an idea what the cause could be?
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/58/64550c6f324c692ca6a6821d1ffbc3.jpg)
484 x 544 - 93K
the hair is attached to a skullcap that should be invisible, but when it intersects with the head very veeeery slightly you get these render errors.
Solution: in the Parameters tab, resize hair/skullcap slightly, usually there is a forehead width/depth parameter or similar.
Thanks Cajhin. That's a logical answer!
