FBX Importing problem from DAZ (mesh deformation)
Its result of importing fbx from daz3d, whith obj its ok, but it hasn't morphs and skin. Is anybody know solution of that problem?
1067 x 652 - 38K
The built-in FBX exporter does not export the corrective morphs. You have to set it up yourself with the Skin Morph modifier, but it's a tedious and time-consuming process, since you have to do all the bones and morphs yourself.
I have had similar issues with Daz. What I Do is export them, import them into 3dsMax, and resave them. 3dsMax will find issues and correct them on import. Of course, you need the program…
Also when you export from Daz and if you I have had similar issues with Daz. What I Do is export them, import them into 3dsMax, and resave them. 3dsMax will find issues and correct them on import. Of course, you need the program…
Also when you export from Daz and if you can, exclude any cameras, props, animations that you do not need.can exclude any cameras, props, animations that you do not need.
