Daz to Blender Bridge not working with environments/props, clothing or animation
![joneienleah](https://delorean.daz3d.com/forums/uploads/userpics/231/nW3S68AAHUB7I.png)
I am a very new user to Blender. I have created a simple scene with animation in Daz (empty room, Gen 8.1 figure, clothing in obj seq I created in CLO3D, and runway walk animation). The whole thing works fine in Daz, have even rendered it out. But I wanted to try rendering the animation and scene in Blender to cut down on rendering time. I am using the Daz to Blender bridge. Export from Daz seems to work okay. Import into Blender is the tricky part. If I click on import new Gen character, she loads in fine, but is missing her clothing, the environment & the animation seems to come in but doesn't actually do anything when I hit play.
If I click import new environment/props I get the error message below. No idea what I am doing wrong or if it is a bug. Please help.
Python: Traceback (most recent call last):
File "C:\Users\jonei\AppData\Roaming\Blender Foundation\Blender\2.92\scripts\addons\DTB\DtbOperators.py", line 305, in execute
Environment.EnvProp()
File "C:\Users\jonei\AppData\Roaming\Blender Foundation\Blender\2.92\scripts\addons\DTB\Environment.py", line 34, in __init__
self.execute()
File "C:\Users\jonei\AppData\Roaming\Blender Foundation\Blender\2.92\scripts\addons\DTB\Environment.py", line 56, in execute
ReadFbx(os.path.join(self.env_root, 'ENV' + str(i)), i, int_progress)
File "C:\Users\jonei\AppData\Roaming\Blender Foundation\Blender\2.92\scripts\addons\DTB\Environment.py", line 84, in __init__
if self.read_fbx():
File "C:\Users\jonei\AppData\Roaming\Blender Foundation\Blender\2.92\scripts\addons\DTB\Environment.py", line 94, in read_fbx
objs = self.convert_file(adr)
File "C:\Users\jonei\AppData\Roaming\Blender Foundation\Blender\2.92\scripts\addons\DTB\Environment.py", line 154, in convert_file
use_prepost_rot = False
File "C:\Program Files\Blender Foundation\Blender 2.92\2.92\scripts\modules\bpy\ops.py", line 132, in __call__
ret = _op_call(self.idname_py(), None, kw)
RuntimeError: Error: Couldn't open file 'C:\\Users\\jonei\\Documents\\DAZ 3D\\Bridges\\Daz To Blender\\Exports\\ENV\\ENV2\\B_ENV.fbx' (16)
Yes. 2.93 lts the enviornment import is BROKEN...
Import into 2.82 lts or 2.90, pack external data into blend file and save as blend file then open in 2.93
