Simple Clarification V6
davidcaputokeenedavidcaputokeene Posts: 131
Should I be able to see/use Genesis Evolution Head and Body morphs with V6? or are there different sets for V6?I cannot find them in DS 4.7 with V6 loaded.
  • FistyFisty Posts: 3,416
    Yes, all morphs for G2F can be mixed together however you wish. Some combinations look better than others.. but you should be able to see all of them.
    Try loading a base G2F, make sure your head and body morphs are there, then dial in V6 (shapes tab, actor, people, real world), then check for the morphs again. If they're there then something is wrong with your install of V6 and the character preset that loads her all complete from the library.. in which case try reinstalling her.
  • Cayman StudiosCayman Studios Posts: 1,135
    The Genesis Evolution morphs are for Genesis figures only (including V5). For V6 you will need the Genesis 2 Female(s) Morphs.
  • davidcaputokeenedavidcaputokeene Posts: 131
    Actually it's worse - they don't appear even with the load of base G2F. I've been having nightmare experience with DIM for weeks. Where should they be?
    As Cayman says, the Genesis Evolution morphs are for the original Genesis, not Genesis 2.
