Help with render
In daz view port I add a texture to a dress or what ever. It looks all sparkly but when I render it it comes out dull. is there any way to fix that
I have 4.7 but it has done this with every version I have had. can't seam to fix that. thanks
    That is probably specularity - the preview can give a misleading impression. How are you lighting the scene?
  • edited December 1969
    mostly with default lighting seams to works the best for me
    Try adding some real lights, shining in from an angle to the camera - you can pick the lights from the view menu and use the standard view controls to place them. You might also try adding some lights at other angles and setting the Illumination parameter to Specular Only for extra highlights without extra light.
    ok I will try that Thanks
