Gunshot Wounds
![blanco1754](https://secure.gravatar.com/avatar/eb5e44a8885c9bb42ff30201c406ae35?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Feb5e44a8885c9bb42ff30201c406ae35_100.png)
in New Users
Bonjour,
J'ai un gros souci avec le logiciel Gunshot Wounds for G8M. A chaque fois que j'applique un impact, la peau du personnage disparait. J'ai tout essayé en vain. Quelqu'un peut-il me donner la marche à suivre ?
Merci d'avance.
The wounds are to be applied to a Geometry Shell, a second isntance of the model that goes over the base model. I believe there should be a preset that will aply the shell for the wounds included with the product.
Bonjour.
Je n'ai pas ce produit, mais en regardant la description il semble que les différentes textures doivent être appliqués sur un geoshell qui se trouve au dessus de la peau du personnage, pas directement sur le personnage (ce qui ferait effectivement disparaitre la peau).
En gros pour les blessures il faut charger le "wound geoshell wearable" d'abord, et appliquer les textures "wound" sur ce geoshell.
Pour le sang c'est pareil, il y a un "blood geoshell wearable" sur lequel on applique les textures "blood".
That is correct.
@blanco1754, If you find the product through Content Library, I believe it's better organized. So you'll find it in the following path > People > Genesis 8 Male > Materials > FenixPhoenix > Gunshot Wounds. There you will find several folders with the correct order of how to apply things. You can find the readme with instructions here: http://docs.daz3d.com/doku.php/public/read_me/index/80852/start You may need to refresh several times for it to show up.
I've downloaded that as a PDF which I'm attaching here for easier access.
Basically, you should NOT apply any of the materials/LIE presets to the character. Instead, you should apply the SubDivision & Geoshell wearables to the characters. Then you would apply the materials (skin color), LIE Presets to the appropriate Geoshells.
Apologies in advance since I don't know frech, I'm using google translate so hopefully the information comes across correctly:
Je m'excuse d'avance car je ne connais pas le français, j'utilise google translate donc j'espère que les informations sont correctes :
@ blanco1754, Si vous trouvez le produit via la bibliothèque de contenu, je pense qu'il est mieux organisé. Vous le trouverez donc dans le chemin suivant > People > Genesis 8 Male > Materials > FenixPhoenix > Gunshot Wounds. Vous y trouverez plusieurs dossiers avec le bon ordre pour appliquer les choses. Vous pouvez trouver le fichier readme avec des instructions ici : http://docs.daz3d.com/doku.php/public/read_me/index/80852/start Vous devrez peut-être actualiser plusieurs fois pour qu'il apparaisse.
Je l'ai téléchargé au format PDF que je joins ici pour un accès plus facile.
Fondamentalement, vous ne devez PAS appliquer les préréglages de matériaux/LIE au personnage. Au lieu de cela, vous devez appliquer les vêtements SubDivision & Geoshell aux personnages. Ensuite, vous appliqueriez les matériaux (couleur de la peau), les préréglages LIE aux Geoshells appropriés.
Really thank you all for your answers. I just have to put all your information into practice, I hope I will get there thanks to you. Again a big thank you.
