Bridge 1.2 not working but previous versions were?
Hi,
I've been using the Cinema bridge successfully for a while but today when I tried to export a figure it has stopped working. For some reason it is now sending the files to my documents folder and not C:Temp3d any more. When I go to Cinema (R20 windows) the plugin can't find anything so doesn'f give me the option to import. I've checked Github and both versions I have installed are 1.2...
Anyone know a fix or, if not, is there somewhere to download the previous version as that was working perfectly
Thanks
Hi,
What I do (R21) is take the file from Documents (I use the file named B_FIG) and rename it DazToC4D. Then in the C: Temp3D folder, I deleted the DazToC4D file in there and moved the file from Documents into the folder. The plugin then will import the renamed DazToC4D file into Cinema 4D.
take v 1.1 here https://github.com/daz3d/DazToC4D/releases/tag/1.1
