DIM re-install of content
jcleaver42jcleaver42 Posts: 10
I want to start fresh with my content. I have already installed my library using DIM, and will soon need to re-install.
Is there an easy way to get DIM to re-install without having to download everything again?
Basically, I want to just delete the content folders and do the re-install.
    Did you keep the installers after installing? By default the option to delete them is unchecked so if you didn't change it you should still have them.
  • jcleaver42jcleaver42 Posts: 10
    Yes, i still have them. I was wondering if there was a way to have the installer re-install everything rather than doing it manually.
    Go to the Installed tab, select everything by clicking the box next to Products, and Start Queue (it will still work even if you already deleted the files), then DIM will show them in Ready To Install.
    Just uninstall (even if the files aren't there any more) and they should appear in the Ready to Install tab, then set the new destination path and install.
