How to light a flashlight?
Hello! Do you know how to light a flashlight like the picture? What type of light do you use?
Thanks!
492 x 443 - 241K
Post edited by bern131088 on
Thanks!
Are you wanting the light cast by the torch, the glow at the end of the torch or the lens flares (or some combination of the three)?
Hi,
I have never tried to render it in DAZ, but I done it with post-work in GIMP. It has a tool called lens flare, that has a nice effect.
Have you tried a spotlight pointed directly at the lenses of your camera in your scene. I would try that in your scene first or a transparent.plane with a few orbs painted on it as a texture., then positioned in between the camera and light source.
For the visible light source: up the ambient to 100%, white and perhaps take limits off the Diffuse strength and increase that (click the gear icon on the slider and go to Parameter Ssettings).
Parenting a spot or point light to the torch will make it cast light, as will applying the uberArea light shader to the torch lens.
For a visible beam, apply a cone primitive and turn its opacity right down low so it just catches a bit of light. You might also adjust the ambient on that.
Lens flare is probably best done in a n image editor, but you could apply a lens flare effect (with a transparency map to match) to a plane primitive.
