Mirroring a joint corrective morph
![TheCediz_2819042](https://delorean.daz3d.com/forums/uploads/userpics/321/nOL8HEUL1RLLE.png)
Hi, I've been struggling for couple hours, now I am here again in search of answers.
All went well for the JCM I created for the left side thigh; I want the JCM to activate when the thigh rotation side-side is active. I create the morph in Zbrush for the left side, make the morph a type modifier/pose, then open property hierarchy to find 1st stage controller of new morph and drag and drop the Left tigh side-side rotation pose I need to correct and it works all well. Up to this I think I'm doing everything okay
The right side is now the problem and it has to do with the attributed sign of the right side it seems (Left bends in (+) and right bends in (-)). So, I grab the morph I made for left side > morph loader pro > hit the morph mirroring option to "swap x axis" (this I'm not sure it's the right option). The morph comes out okay for the right side. In property hierarchy, I do the same as the left side but for the right tigh and now, the resulting JCM is kinda inverted. I want the morph to go from 0 > 100 when the joint (R side-side bend) goes open 0 > -50. As of now, my morph is applied (+) when the bend closes -50 > 0.
Is the problem with the right side in property hierarchy or when I mirror the morph in morph loader pro? I think I would need my morph to invert the sign, so instead of gradually applying from 0 > 100, it would applies from 0 > -100, as all Right pose transform do. How can I do that?
Any alternative?
Big thanks
Yes that is a 'fun' situation. Needs 3 morphs ;-) Here's my little tutorial on how to:
https://sharecg.com/v/97315/view/3/PDF-Tutorial/Making-pJCMs-for-Clothing
Aren't you exactly what I needed; not the first time you save my ass Catherine! I'll make sure to follow and check out everything you have on ShareCG.
Thank you!
You're welcome :-)
I do not know all the deep dark secrets of making joint corrections etc. but enough to tippy toe through the waters now and then ;-)
For anyone having the same problem if it is a negative bend:
you drop the controller morph/pose in Propperty hierarchy > your JCM/MCM > controller > 1st stage. Then under the morph in 1st stage > Attribute > Scalar ; set the number to negative.
Hi! the link doesnt work!
