Will it work with Michael 6
kathils01kathils01 Posts: 49
edited January 2015 in Hexagon Discussion
I'm new to Hexagon. I got it to do facial morphs. I'm able to get it to work with Victoria 4 but nothing else. Does it work with Michael 6 or the Gen2 male??? Every time I try to import a morph, created the same way I do for Victoria 4, I get this error:
Warning: Geometry did not match, failed to create morph.
Any ideas?? I'm in Windows 8 64 bit Daz 4.7 Pro
Steps I'm using with Victoria 4 are to export just the head as an obj
Import to Hexagon
Make changes
Export as obj
Use Morph loader to bring it in.
Also, I can't seem to use my Wacom tablet with it. The cursor freezes. Anyone have any input on that as well?
Post edited by kathils01 on
  • fixmypcmikefixmypcmike Posts: 19,597
    For Genesis/Genesis 2 you need to set resolution to Base Resolution before exporting.
  • kathils01kathils01 Posts: 49
    Where do you set that? I don't see any option for it in the export box. Not when exporting out of Daz, or out of Hexagon.
    Parameters pane > Mesh Resolution > Resolution Level
    That didn't seem to work either. I'm including screen shots of the defaults in the dialog boxes as I
    1) Export from Daz
    2) Import to Hex
    3) Export from Hex
    4) Launch Morph loader in Daz
    5) End result
    527 x 520 - 27K
    527 x 520 - 50K
    420 x 330 - 45K
    420 x 330 - 43K
    493 x 591 - 60K
