Normal Map Fusion (Commercial)
Welcome to the Normal Map Fusion Thread. Please feel free to ask any questions regarding the product. Product is yet to be released.
1000 x 1300 - 795K
2000 x 1066 - 1M
1000 x 1300 - 686K
2000 x 1066 - 959K
2000 x 1066 - 992K
1000 x 1300 - 664K
2000 x 1066 - 1M
2000 x 1066 - 936K
2000 x 1066 - 999K
Post edited by Zev0 on
Redacted
Sure, you can edit them manually in an image editor one map at a time, but then you are overwriting an existing file unless you save a new one and link that to your skin. Also transparency (alpha) is not the correct way to blend normal maps which preserves detail. You need a specific overlay function like in photoshop to do that for normal maps, we created a new blend process to mimic this that studio was not capable of.
This also saves out a new normals set leaving source maps intact and auto applies it to figure. You can also live preview the blend strength of maps and changes on the fly.
End of the day this was designed so you won't have to leave studio and can do everything inside it, and it does it faster than the manual editing process.
Sounds interesting. Guess it will support both G8M and G8F plus 8.1?
Redacted
From G3 to G8.1 both male & female. We included G3 support since base UV is the same as G8.
This sounds very interesting!
Nice to see that this is finally out! In the cart now. :)
Hi Zev0, what technique is used to blend normal maps?
Thanks.
Hi. It's a custom action we created for studio. We had to create a new blend method that didn't exist.
Hello,
Is this a Merchant Resouce?
Thank you!
The product itself is not a merchant resource. However, it can be used to blend different normal maps together to make a new one for a merchant resource. The only catch is you cannot use normal maps from characters or other purchased sources(texture packs) that specifically prohibit any portion(in part or in whole) of the texture(s) from being copied/edited and then sold/distributed. For personal use you can do whatever you want, but when making a merchant resource for distribution, you need to be mindful of the resources you're using to make it & any constraints tied to those resources in this regard. For example, you will not be able to blend the normal maps of any characters sold here at Daz and sell/distribute the resulting normal map as a merchant resource as that would be copyright infringement, at least as far as I know.
Yes that is correct.
Hello!
I'm sorry, but I'm in need of some assistance. I clicked the "product support icon" in the script (I think) and this is where it took me. Basically, I'm able to add the script to my toolbars and I can check to verify if Normal Maps exist in a preset (It says "JOY! they do", or something similar), but when I click to launch the main script it doesn't see the normals I want to blend in. I can't browse there manually, either. Is there a step I am either missing, or is there a commonly ask question page or something I should reference?
Thank you very much!
Hello,
I have the same promblem as duckbomb. It is not possible to blend in a second characters normal map.
Thank you
Please video tutorial!!!!!
Will this work with Studio version 4.14.08? I have G8F selected in viewport with normal maps on, tried launching NMF for first time. All I got was error message: "An error occurred while reading the file, see the log file for more details."
Log file simply states:
2022-05-04 16:12:49.893 Loading script: C:/Users/Public/Documents/My DAZ 3D Library/scripts/normal map fusion/normal map fusion.dse
2022-05-04 16:12:49.893 Failed to load script: C:/Users/Public/Documents/My DAZ 3D Library/scripts/normal map fusion/normal map fusion.dse
Hi. Earliest is 4.15.0.2
Thanks. Looks like I'll need to install the Public Beta version then.
No way to make it work in DA 4.20.
After the blended image appears the program stops. No buttons appear in the pop up window, apart from the usual Minimize, history and cancel buttons, if I close the blended image the programs stops
Here is where the script stops.
Windows 11, Intel I9, Nvidia RTX 3080 with 16 GB Vram, 32 GB ram, MSI notebook, nvidia game driver updated
Can we get some clear instrutions on how to choose another set of normals the script keeps telling me to choose a duf when I do it tells 2 dufs can not be selected
Can I get a log file when this happens please. Thanks
Hello, I just recently purchased this product and I've been experiencing an issue with the dialog box for the blending process not fully popping up so I can click the "Next" button to complete the blending process. I can see the normal map but just not the bottom portion and there is no option to make it ful screen. Any advice or direction would be much appreciated, thank you. Other than that you make awesome products!
(Edited by mod to fix formatting)
Hi. Have you tried pulling the corner window to expand until you see the bottom options?
Hello. I'm having the same issue as the above poster. I just recently purchased this product and I've been experiencing an issue with the dialog box for the blending process not fully popping up so I can click the "Next" button to complete the blending process. I can see the normal map but just not the bottom portion and there is no option to make it ful screen. Any advice or direction would be much appreciated, thank you.
Well, I came here to ask about a probem I'm having with Normal Maps Fusion for Genesis 3, 8, and 8.1, but I noticed that several people seem to have asked about this exact same problem two years ago and never got a reply. I'll ask anyway. When I try to blend normal maps, after I press blend, and the preview window pops up, I can't go any further becaus the window extends past the bottom of my screen, so I can't even see the bottons that allow me to move forward. There seems to be no way to resized the window in any way that can solve the issue. Is there a solution for this, or should I just request a refund?
Hi. What size is your screen? We develop most products for standard 1080p resolution.
My screen is 1080p. Having said that, I went to check my display settings and discovered that it was defaulted to the "recommended" zoom of 125%. Once I switched it to 100%, the window was the correct size, and I could see the buttons. So, yeah, sorry for troubling you.
NP. I was going to ask next what the default zoom value was.
Glad its sorted.
