AA light dosent work or I do something wrong ?
I just installed Adwanced ambient light and I think this n does not work correctly.
AAL does not give all the lights and you can also set the position, there are only shadows and light intensity.
Example
1.Imaga with no light
2.Image with AAL
1024 x 576 - 313K
640 x 480 - 15K
640 x 480 - 132K
Post edited by calaopie on
Did you install manually or with the Install Manager?
Manually
have you checked the light intensity setting in Parameters, maybe it is to low.
I use AA Light most of the time and it works fine with DAZ Studio 4.7
You should also have several Options within the Parameter Tab.
Manually
There are support files that need to go in the application folder - did you place those correctly, or just extract to your content directory?
/scripts/support/AgeOfArmour/Light/AoA_AddShaderMixerAttributes.dsa
/scripts/support/AgeOfArmour/Light/AoA_AOLightAttribs.dsa
/scripts/support/AgeOfArmour/Light/AoA_AOLightDef.dsa
/scripts/support/AgeOfArmour/Light/AoA_AOLightParams.dsa
/shaders/AgeOfArmour/Light/AoA_AOLight.sdl
all need to be in the application folder, in the listed sub-folders. For things like this it's geenrally best to use DIM even if you don't use it for plain content.
