what can i anticipate from c85 animation? does ca85 hair animate? wind forces?
Mistara
does it have wind dynamics for it's dynamic hair? cloth?
what about particles?
does it have the linear thing? will my spaceships start bouncing?
i'd like to make a real effort to do a show reel.
Post edited by Mistara on
this is all i found so far
Non-Linear Animation Track Groups - Using Carrara for creating animations? This merge track tool will provide an improved interface to create groups of tracks then collapse or expand the tracks in those groups.
Ocean Primitive - Simulating the surface of the ocean, this feature can be used to create both still and animated oceans. You will be able to control the waves, plus the speed and direction of the wind.
the storyboard is a whole nother topic, don't know where to start with it?
looks like dynamic cloth is called 'soft body dynamics'
not seeing anything on wind and hair so far
Yes, soft body physics is the closest to Poser dynamic cloth.
you should also check out Carrarators.
http://www.daz3d.com/forums/discussion/50679/
i watched the pretty princess clip, the hair was static. made me worry.
these were kewl. :)
Carrara Physics Tutorial http://www.youtube.com/watch?v=NcuVx3Zdyfs
DAZ3D Carrara 8 - Bullet Physics http://www.youtube.com/watch?v=4cMS4exs5k0
If you are interested in dynamic hair, you might be interested in
https://www.youtube.com/watch?v=nLn1DQmsR6U
thanks!! :)
i been sidetracked a little with the physics stuff. fascinating to watch
If you like Physics and particles, then these videos by Age of Armour should inspire you:
https://www.youtube.com/watch?v=_eDov7NwxGU
https://www.youtube.com/watch?v=-XGRj4VjPqk
https://www.youtube.com/watch?v=UFxGFPoyXXc
the motion path and banking thing sounds helpful for dragon flights :)
Chapter 18: Animation Techniques
Always loved those Age of Armour animations EP!
When it comes to Physics and Particles, I always think of DimensionTheory's beautiful vids:
https://www.youtube.com/watch?v=Abp0_tkIn00
https://www.youtube.com/watch?v=92m4xu_Y5bs
and so many others :)
does the marble have to spin down the path? was just thinking, parenting dragon to it, i want the dragon to bank but don't want it to do stomachsaults.
still don't know enough to have an animation strategy.
you can use a track modifier not tracking rotations only transforms or also convert the physics to keyframe and edit those
physics is fun btw
https://www.youtube.com/watch?v=y4Aw9OdyZ6s
https://www.youtube.com/watch?v=gGVFu5wBI_A
https://www.youtube.com/watch?v=3eMPh-FpkNE
https://www.youtube.com/watch?v=4DWHH5aICMc
Misty, there are also motion paths that can be used. I usually use the path and if I have a rough spot that I can't fix, I convert back to keyframes to edit the movement.
I did this video years ago as an experiment with motion paths (no audio):
https://www.youtube.com/watch?v=xBX28ZsaVUg
Then there's the automation that is possible using Inverse Kinematics, target helper objects and IK tracking. The sprocket with the pedals has a rotation behavior assigned to it, and the feet are set to track the target helpers parented to the pedals. The hands are set to track targets parented to the handle bars. I did add some hand animation to the torso and head so that they didn't lurch from side to side and looked more fluid.
https://www.youtube.com/watch?v=fl5mq9Sdpwc
the promo for Dynamic Skye Hair looks amazingly real. woww!!
