Batch process G8 geoshell presets to G8.1
in The Commons
Hi,
The G8 geoshell presets to do not transfer to G8.1 Torso. A lot of vendors are selling products using the geoshells and a lot of customers want to
update their purchases to G8.1 geoshells.
As a vendor I have a lot of G8 products that are for geoshells that do not work with G8.1.
Also Customers are contacting me how to use them on G8.1.
Is there a script that would change the torso to head, body so I could batch convert all of my G8 products to work with G8.1.
Even if I knew how to replace the torso text with head, body text it would be a great help for batch conversion.
Any help or advice would be greatly appreciated.
Cheerio
lululee
I asked about this (a script) a few months ago and there has been few posts since then, but nothng of interest has happened. I actually think a geoshell 8 <> 8.1 conversion script would be a great seller. Don't know why no PA seems interested it it.
I don't know if batch conversion is going to be possible but I may be able to do a couple of utility scripts to be used on a case-by-case basis - would there be interest for this?
Hi Silas3D,
For sure I would be interested in your scripts. Please keep me posted.
Cheerio
lululee
Count me as interested to
Generally I do once a Head version of the textures (or LIE for tattoo), Body surface can use Torso texture. It's easy to create a new Material preset.
It takes less than 5 min.
Note: you can also select Genesis 8 UV set in the geoshell (For example Base Female instead of Base 8.1 Female)
I've found that, to solve this problem, you can simply add a Surface Selection Set to the geoshell called Torso, and add the Body and Head surfaces to the selection set. Then, with the geoshell selected in the scene, any preset will load correctly.
For anyone unsure of the process, you select the geoshell in the Scene Tab, then go to the Surfaces Tab. Open the side menu and click "Edit Surface Selection Set(s)".
In the new window, add a selection set in the left pane and call it "Torso". Then select "Torso" in the left pane and tick "Body" and "Head" in the right pane. Click "Accept" and then go on to load your G8 preset. It should load normally without any further editing required. If there is any issue, just change the UV of the Body and Head surfaces to the UV of the geoshell preset you're applying.
e.g. in the case of Jepe's Bodyhair Project 78, the presets load fine after adding the Surface Selection Set but, if they didn't, you could simply apply the Base Male UV to the geoshell surfaces to fix any problem.
As an afterthought, you could also save the geoshell as a Wearable Preset after adding the Surface Selection Set, and load that preset onto a G8.1 figure whenwver you want to use it in the future.
I forgot this "Template" method like Legacy UVs products do to apply old material presets.
@Dresdenskin
I have submitted a feature request for this to be supported by default.
Attached is a script for creating a geometry shell with the following properties on Genesis 8.1 Male or Female figures
I signed in to the forums for the first time in a long time just to say thank you for the script. It worked like an absolute charm. THANK YOU THANK YOU THANK YOU!
thanks
Wow. Works like a charm. Thanks for this!
Perfect! Thank you.
Cool! Many thanks!
This is an invaluable tool for several products that rely on geoshells and PAs that haven't updated to G8.1, thanks so much for this!
The script creates a geoshell for 8.1 bur it's all white - what did I miss?
Nothing.
That's how all geoshells load.
All white and 50% opaacity.
You could probably add something to the script if you want something special to be applied to the geoshell after it loaded though.
This "just works" for the character skin. Feels like it should be something that Daz does automatically in the same way.
If a geoshell is used on a G8.1 and its surfaces are clearly those of a G8, then Daz Studio itself should spot that and perform the conversion. It should not require a script. That's your batch process: you load it, Daz converts it, it works.
That's my view anyway. Maybe it's not that simple, but I can't see why not. (But thanks for the script!)
Any possibility for having this script for G8/8.1 geoshells to Genesis 9 ?
thanks a lot, very useful! ^^
I was just trying this out again and can no longer figure out how to make it work. Looking at the screenshot, can anyone tell me what I'm doing wrong?
Sorry. Here's the screenshot
On a different note... I just made a set of two images to go with the script, consisting of the regular 91x91 png and the 256x256 tip png. I placed the script itself into a sub-folder in my Daz scripts folder that I named OmniFlux, and then placed these two pngs in there, though of course you can place all these wherever you like in Scripts. (I also placed a browser shortcut to this thread in there for completelness, although that won't show up inside Daz's interface.)
Make sure that the .png and the .tip.png are both named the same (to the left of the first dot in the names) as the script for it to work right.
Go to Surfaces pane, select all Surfaces, in slot UV Set, choose "Geoshell Body Suit A"...
Some unique geoshell clothing use custom UV Set other than Genesis X Base Female's... while the script doesn't know what the dedicated UV Set is. Just manually assign it accordingly. Then save a Material Preset(s) to the product folder or your Preset folder.
