Deep Texture Editor question
Hi....
In the sample you see a material called rock grid...
My question :
In component 2 you see that the squares are show up in a angle....
Is it possible to get the square's in component 2 straight ? I tried the phase option.. but it doesn't affect the squares at all.
regards: Atlantis
639 x 475 - 61K
Select the noise for component 2 and you get a similar pop-up as the one for Phase you are showing. Then rotate Direction.
Yes it is.
Image 1, open the noise tool and dialogue and set the xy rotation to 90
Image 2, change the mode to minimum 90
If you want the component "square" in 3 dimensions as well as in the xy plane, also set the yz rotation to 0 (or any multipleof 90).
Did that do what you wanted?
@ David...
Excellent!!!.. thnx for your fast help...
I tried all the time using the phase option
