Victoria 4 skin texture issue? SOLVED
EamonEamon Posts: 159
Working on a book cover and all is approved by publisher which is great.
Today I go to make the hi res render (2543 x 6343) of the main figure and I get crazy bad quality on my render?
I changed skin textures but the effect is still the same.
What am I doing wrong this time? Any help would be much appreciated. :)
700 x 910 - 342K
Post edited by Eamon on
    The skin problem is probably a need to lower the Shading rate for all skin surfaces.
  • EamonEamon Posts: 159
    Ah! I had it at .50 but have just taken it down to .010 and it's now taking far longer to render which is a good sign. :)
    Will post with result.
    Thanks Richard, that was the issue alright. Not sure how I managed to have it at that setting. It's actually still rendering but her face is all good now.
    I often post small little questions like this so if you or other admins feel that they have served their purpose and have no use, then please feel free to delete such threads. :)
    It's useful to keep these threads around, in case someone else has the same problem. You can edit your first post to put "Solved" in the title so people searching know a solution was found.
