Rig in T pose and mesh in A pose after import
![hannahliebeeeeee](https://secure.gravatar.com/avatar/f91457062abe221dd5689f43596b4db6?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Ff91457062abe221dd5689f43596b4db6_100.png)
I am using the latest daz version and I am trying to export a character to maya and I am using the daz to maya 1.8 plugin. no matter which model I choose and what export settings I use I always get the same result in maya:
Has anyone an idea what the problem could be? I tried reinstalling both maya and daz but it doesn't seem to fix it. also tried using maya 2020 but also doesn't help.
If anyone can help or has an idea, thanks in advance.
Same problem here, manually correcting the rig does not help.
This seems to be somehow related to including morphs that aren't supported. I got this when I included a few Genesis 8 morphs on a Genesis 8.1 figure, but it went away when i made sure that my morphs were 100% meant for my figure.
I would go back through your morphs and only include ones that you plan to manipulate in Maya
Hi guys
Try it and return to write here if work: on DAZ Studio, re-scale your model to 100% - use bridge.
Waiting your answer here (this method work for me)
I get this only if i select SubD level 1 or level 2 on level 0 is working fine did any body found a solution to make it wotk with subd 1 and 2? How to re-scale the model to 100 i dont understand that my caracter is already at 100 scale i made it 90 and again 100 i tried again did not solve the probleem
