Animate surface properties
peter.eisenmannpeter.eisenmann Posts: 5
edited December 1969 in Art Studio
Hi,
simple question:
When I change a surface property, e.g. set opacity from 100 to 50 on frame 10, the opacity is 50 when I go back to frame 0.
Is it really not possible to change a surface property over time?
  • Richard HaseltineRichard Haseltine Posts: 102,344
    Not easily, no. One option is - assuming you are using DAZ Studio - to use the Shader Mixer where you can get the frame from a Variable brick and use that to control a property.
  • peter.eisenmannpeter.eisenmann Posts: 5
    Thank you for this very fast answer!
    Yes I use DAZ Studio. Not 100% sure what your answer means, but I will find out :)
    I just wonder if there never was any demand for this feature, as I cannot imagine it being a problem to implement? These are just numerical values after all :)
    Thanks again
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,510
    Casual has a script too, click Richard H's scripts link in his sigline you will find it in that thread, is called matanim
    There's certainly demand for animatable material settings, but they haven't (yet) been implemented.
    Thanks a lot for the tip Wendy, unfortunately the download link is dead.
    edited January 2015
    I always get a 415 error when I click the download link. Would you mind to send the zip file to peter.eisenmann AT gmx.net?
    Post edited by peter.eisenmann on
    Sorry I cannot only Casual can and might if you PM him or at least help you find the reason, I suspect it is google sites related and your browser having a setting to block it.
    As I use Gmail I am signed into google but if you are one of those who avoid all things Google it may affect the ability to download.
    Ok I can understand that. I am actually signed into google, still get the error, maybe it's really browser related. So I will contact casual then. Thanks again!
