Obj export - Losing the origin/hot pt
TangoAlphaTangoAlpha Posts: 4,584
I'm trying to export a simple prop (a door) from C8.5 to use in Studio. The problem I have is that in Carrara, the hot point is at one edge of the door - at the hinge. But in the obj file, the hotpoint gets centred, so the door rotates around its mid point and not around the hinge.
(The issue happens even if I reimport the obj to C8.5, so it's an export problem rather than an import one). Short of adding an invisible counterweight to the door (!) any idea how to fix the export?
Ta :)
1276 x 833 - 700K
1353 x 861 - 838K
  • V3DigitimesV3Digitimes Posts: 3,181
    Fixing the export I could not say. I have the same issue when I export from blender.
    You can solve this directly in DAZ Studio : select your door, activate the joint editor tool (ALT SHIFT J) and you have arrows allowing you to move the origin of the object in DAZ. Once done, save as figure/prop asset, and when reloading you should have your door with the origin on the right place.
  • Philemo_CarraraPhilemo_Carrara Posts: 1,175
    edited January 2015
    Ta :)
    Yes, it does that :-(.
    If, instead of using hotspot, you translate the mesh in the vertex room so that the hinge is in 0 in X and Y axis, it is preserved in export/import if using the FBX format. Cannot try with studio right now, but it may work.
    Post edited by Philemo_Carrara on
    That does the trick - kinda like CapsLock in Carrara. Thanks :)
    You're welcome. I'm glad I could help.
  • DUDUDUDU Posts: 1,945
    Ta :)
    A question (perhaps stupid), why do you want to work in DS if you own Carrara ?
    DS could be a "plugin" for Carrara and not the reverse... ;-)
    edited January 2015
    Because not everyone else is so enlightened... ;-)
    Post edited by TangoAlpha on
