How to fix height?
nikijunpei81
in New Users
Hi. To give more realism to my characters, I use measure metrict for heights and other spec., but, anytime i load a preset pose, this settings vanishes, and chara get different heights and measures. How can i fix it? There is a way to block height of genesis using measure metrics, even when i load a preset pose?
Thank you.
How did you go about adjusting the height because depending on the way it was done it can be overwritten when applying a pose.
Hi frank.
in the way you can see in the attachments. Using scale for height, and disable local trasform for waist, hip and bust.
Poses may well work on transforms, so it would not be altogether surprising if they zeroed the scale - especially if theya re freebies etc. where the make may not have known to be selective with which properties they included in the pose.
It's really hard to found the height you want from a pose preset. In standing pose is simple, but in sitting or laying pose it's really hard, because figure metrics did not give me the correct data. Othewise i could resolve with a manual adjustement. That's why i'm askin about correct settings and tips to block the height.
Any other advice to fix the height using figure metrics using preset pose? Idid not understand yet how to setting the height in the right way. Thank you anyway.
To keep any scale adjustments I save out the basic figure with the scale slider padlock locked then apply poses. I'm not sure if that's any help....
