Genesis Evolution
Last saturday I bought and downloaded Genesis evolution, but I can't find it in my Daz studio 4. I watched some you tube
film about it, but I don't have the panels where trey should be.
Genesis 2 is installed and also Genesis Evolution: Body Morphs and Genesis Evolution: Body Morphs are installed.
I don't know if it has something to do with my genesis evoution problem but there is an installing problem with Photoshop
3D Bridge for DAZ Studio 4.7+ (Win 64-bit): install failed (The same for Photoshop 3D Bridge for DAZ Studio 4.7+ (Win 32-
bit)).
Install Manager cannot find a required path. The package for "Photoshop 3D Bridge for DAZ Studio 4.7+ (Win 64-bit)"
requires that the installed path for "Photoshop CC, CS6, CS5, CS4 (64-bit)" be defined. Make sure that a path for this
application is present on the "Applications" page of the "Settings" dialog, then try again.
The Genesis Evolution morphs are for Genesis, not Genesis 2. There are separate morph packs for Genesis 2 Male and Genesis 2 Female.
Do you have Photoshop? If so you need to click the gear icon at top-right of the Install Manager window to open the preferences, then go to the Application tab, click the + button and set the options in the dialogue to Photoshop, your version and bit-depth, and then click the ... to select the application folder.
Thank you very much, I see I still have to learn a lot.
