DAZ Main menu changed or corrupted after cancelling render
mikey186mikey186 Posts: 84
After I gave a test run on luxrender, my PC was completely slowing down so I stopped Reality, LuxRender, and DAZ entirely and restarted, and I saw the main menu has completely changed on it's own after it's slow down, I tried putting it back together, and all I see is duplicate menu items that cannot move. I can't even fix this problem help????
top - default menu; bottom - changed menu
371 x 180 - 24K
Post edited by mikey186 on
  • Richard HaseltineRichard Haseltine Posts: 100,843
    Try reloading your layout. If you hadn't saved it you will need to reload one of the defaults. Then go to Window>Workspace>Customise to recreate the Scripts menu (Menus tab, expand Main menu, right-click to add a new menu, name it scripts and drag into place) an restore your Custom Actions (find them under Custom Actions on the left, drag them into your Scripts menu). Once you have the layout correct, save it from the Window>Workspace menu.
